Παιρνετε ενα καινουργιο ποδηλατο ! Αγοράστηκε τον Δεκέμβριο η τιμη περιεχει ολα τα περιφερειακα πετάλια ultegra, specialized power σελα, φωτακια κτλ,
FRAME MATERIAL Carbon FRAME MAX technology carbon, disc, BB86, 142x12 mm thru axle, R.A.T Evo technology, Di2/mechanical, flat mount 160 mm, internal cable routing FORK Carbon, disc, 100x12 mm R.A.T thru axle, R.A.T Evo Technology, flat mount 160/160 mm, internal cable routing SHIFTER Shimano 105 R7025 FRONT DERAILLEUR Shimano 105 R7000 REAR DERAILLEUR Shimano 105 R7000 SPROCKET Shimano 105 CHAIN Shimano CN-HG601 CRANKSET Shimano RS510 BOTTOM BRACKET Shimano Pressfit Road BB86 TRANSMISSION OF DRIVE front: 50/34, rear: 11-34 HANDLEBAR BBB Deluxe, aluminium, drop: 125mm, reach: 70mm GRIPS FOCUS Bartape SL STEM BBB Rider BHS-109 Deluxe, 31.8mm, 7degree HEADSET Acros, IS 52/40-IS52/42 SADDLE Specialized Power SEATPOST FOCUS Aero Carbon, D-shape, 350mm, set-back: 15mm BRAKES Shimano 105 R7025 BRAKE LEVER Shimano 105 R7025 BRAKE Disc WHEELSET Novatec 30 CL, 622/20, disc, center-lock, front: 12x100 mm, rear: 12x142 mm TIRES Vittoria Zaffiro, 700 x 25C, Folding GEARS 22
![]() | 110.43 KB |
![]() | 93.44 KB |
